66 C2 DOT#5 Brake fluid "disappears" during Winter Storage - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4498
    Re: 66 C2 DOT#5 Brake fluid "disappears" during Winter Storage
    Originally posted by Gary Beaupre (28818)
    Larry,
    I prefer data to theory. Next time you bag the car do the open container of DOT 5 test and mark the before and after level. Regardless of the speculation of some, I believe the evaporation will be nowhere near 80%.
    Gary
    Right. Evaporation cannot explain 80% loss in a small sealed (or virtually sealed if there's a leak) system. The fluid is going somewhere; you just haven't yet discovered where.
    Keep us posted what you find.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Larry E.
      • 1652
      Mark: Thanks for reply. One must remember the manual brake master cylinder on a 66 is NOT THAT BIG TO BEGIN
      WITH. SO>80% sounds like a lot but it is not that much. The can of DOT#5 from the parts store is not that big and
      it hardly uses 50% of it. Thanks to you and everybody else for all the advice. Will keep a close eye on this and will report
      the outcome when I know it. Larry
      Larry
      LT1 in a 1LE -- One of 134
        • 6940
        #18
        Larry, another thought was to check the boots around the pistons for sweating, any wetness around boots is a sign of fluid behind the boot. Sometimes if you take a pocket screw driver you can peel boot back slightly if you see fluid you found your leak.
        • John F.
          • March 23, 2008
          • 2395
          #19
          Check every line from front to all four corners, up to and including the brake calipers.
          • Jim D.
            • 2882
            #20
            I installed DOT#5 in my 1960 back in 1986. Every component of the brake system was new or sleeved at that time. I checked the level in the M/C a few days ago in preparation for summer driving and the level is the same as it was in 1986. That stuff doesn't evaporate.
            • Owen L.
              • September 30, 1991
              • 838
              #21
              Can't help but throw my hat into the "doesn't evaporate" ring. It's difficult to find evaporation ratings on silicone brake fluids (or even Dot 3,4,5 fluids). However, if you look at the MSDS for silicone brake fluids, you'll find they indicate something along the same lines as this:
              Inhalation: This is a viscous fluid that does not easily form a mist or vapor and, therefore, inhalation hazards are minimal.to?
              • Larry E.
                • 1652
                #22
                Owen: Thanks for reply. Let's explain the "Car Jacket" Procedure> After car is in the bag a package of "DRY-Z-Air" is put in a container made of of White Pellets. It's job is to draw out all moisture into the container which becomes a liquid. In it's makeup the liquid in the
                container WILL NOT RE-EVAPORATE INTO THE BAG. This liquid is thrown away when car is taken out of bag. Don't ask how
                this works. I guess these white pellets "stimulate" evaporation in the bag and turn this moisture into liquid. A lot of Motor
                Home guys use this stuff to store their units. This with "no pedal usage" and small shrinking of the seals causes some of
                the brake fluid to escape and evaporate into the container. This is my theory for now since everything returns to normal during
                the Summer Months. Larry
                Larry
                • Patrick B.
                  • August 31, 1985
                  • 1986
                  #23
                  Larry- If any of the DOT 5 makes it into the container with the water, it will not mix with the water. The container would have two separated phases of liquids. I suppose the Silicone fluid would be the top phase. Do you see distinct phases in the liquid container?
                  • Owen L.
                    • 838
                    #24
                    Just my armchair mental musings: Even if it did evaporate easily, I don't see how it's going to get out of the sealed brake system by evaporation only. Losing 80% (of what, a cup of fluid?) isn't going to seep away invisibly. The molecules are pretty large to go through the rubber seals and hoses. If the material pores were that large, water would be seeping in at alarming rates.
                    • Larry E.
                      • 1652
                      #25
                      Patrick>I use 3 containers per car when I bag them. All of the containers are full(Liquid) in the Spring when car is taken out of the
                      bag. I really have not noticed(or looked that closely) if there is more then one phase. I DO KNOW THAT THIS LIQUID IS
                      VERY NASTY STUFF. WHEN I DUMP IT ALONG MY BUILDING OR FENCE LINE IT MAKE THE BEST WEED KILLER YOU
                      EVER USED! I will look next time. Thanks/Larry
                      Larry
                      • Larry E.
                        • 1652
                        #26
                        Owen>Thanks again for reply: I suppose we can go on and on about the theories of why this is happening. HERE IS THE BOTTOM LINE>
                        WHY DOES THIS HAPPEN ONLY WHEN STORED IN THE WINTER WHEN CAR IS NOT USED AND DOES NOT HAPPEN
                        IN THE SUMMER WHEN CAR IS USED. STILL WAITING FOR A LOGICAL ANSWER. LARRY
                        Larry
                        • Larry E.
                          • 1652
                          #27
                          Thanks again to all that are trying to help. I SHOULD HAVE ASK THIS QUESTION A LONG TIME AGO WHEN
                          THIS STARTED.>>
                          DOES ANYBODY ELSE ON THIS DISCUSSION BOARD USE THESE "CAR BAGS/OMNI BAGS" FOR STORAGE IN THE
                          WINTER THAT USE DOT#5 BRAKE FLUID??? OR KNOW SOMEBODY THAT DOES.> LARRY
                          Larry
