69 L46, 4 speed.
I am preparing for a PV in a month and struggling to find vacuum leaks. PV test says the headlight doors should be able to be closed 2 - 3 minutes after the engine has been shut off. I knew I had a bad leak since the engine was running rough, stalling etc from time to time. Using an electric vacuum pump I found a leak on the headlight override switch under the dash and replaced that. Currently the headlight doors will close 1 minute after engine shut off, but not after 2. Engine runs great. But still leaks to find. I have read in several threads that a smoke machine can be real helpful in locating leaks. I got one last week and started to use it today. It has a pump internal to the bugger and does make smoke. Yet, when I connect to the system (after the check valve and with the heat control system isolated out) there is no leaks showing. I am wondering if I have to vent the system to allow the smoke to circulate? Any suggestions will be appreciated.
Rich
Rich
