68 Hood Support - NCRS Discussion Boards
68 Hood Support
  • David M.
    • September 30, 2004
    • 515
    68 Hood Support
    Couple of questions on 68 hood supports:
    Was there only one design? I remember a few years ago seeing one of the vendors offering 2 or 3 designs for 68. Now I can only find one.
    Which vendor offers the the best one?
    The car has what I believe is a OEM Big Block/LT1 hood on a small block car. I remember back in 2009 or so trying to find one that fit & function but no luck.
    I'm going to attempt this exercise again getting sick of the prop rod.
    Any advice is appreciated.
    Pictured below is CCs part number 463019
  • Gary B.
    • July 31, 1979
    • 926
    Re: 68 Hood Support
    Two designs for 68. First design pictured above. Second design, introduced around March 21st, 1968, used a third hole on the hood lip. My April 1st car uses the second style. Both designs are available through most parts houses.
    Gary Bosselman
    • David M.
      • 515
      Re: 68 Hood Support
      Thanks Gary,
      Its an April build.
      Ill continue to surf.
      • David M.
        • 515
        Re: 68 Hood Support
        How about a picture of a late design hood support. No internet luck...yet.
        How different is the late vs early design? Length or hole and mount design?
        I'm also studying the hood.
        Looks like a 68-71 hood uses a longer support as the mounting holes are farther away from the hinges verses a 72, which are closer and uses a shorter support.
        Any truth to this?
        Time to get out a tape measure and examine the AIM.
        Its possible the hood is a 72 LT1 or BB. It was on the car when I bought it. Could be a mismatch here, trying to mate to the 68 inner fender??
        • David M.
          • 515
          Re: 68 Hood Support
          Think I'm catching on. I'll inspect the mounting hole locations on the inner and the hood tomorrow.
          If I'm interpreting this correctly the later 68s use the 69-71 support??
