1970LT-1 TCS query - NCRS Discussion Boards
1970LT-1 TCS query
  • Dennis D.
    • March 1, 2000
    • 1071
    1970LT-1 TCS query
    I've been asking all over about this. Before I hack up an lectric limited engine harness, trying to get an answer.
    Did the 70 come with a jumper extension for the TCS connection to the temp sensor? The LL harness has the green wire continuous from the harness to the temp sensor.
    My LT-1 as well as my L-46 had the jumper. LL is standing firm on 70 not having it. Knowing there were other changes for" new ideas" from 70,(hl washers moved, studs to screws, front grilles, etc. )
    Maybe the solid wire burnt so often, needing a spliced repair, that for 71 on, there was the jumper?
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1970LT-1 TCS query
    I'll get a picture Sunday for you. Out of town, Chapter Meet.
    Gary Bosselman
    • Dennis D.
      • March 1, 2000
      • 1071
      Thanks Gary. Are you with or without jumper?
      • Mark E.
        • April 1, 1993
        • 4498
        Plug-in jumper on 1970 LS5 #12931
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Dennis D.
          • March 1, 2000
          • 1071
          �� Thanks Gary. Just for kicks, early or late car?
          • Dennis D.
            • March 1, 2000
            • 1071
            Thanks Mark. Early or late car? Maybe a mid year change. Here's a good pic of the jumper.
            • Mark E.
              • April 1, 1993
              • 4498
              [ATTACH=CONFIG]122220[/ATTACH]
              #12931 is June 22.
              I thought all 1970s used a pigtail/jumper for TCS. Have you seen one that's different?
              I'll look, but believe the CSM shows a connection. I think Doc Rebuild's diagram shows a connector too.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Dennis D.
                • March 1, 2000
                • 1071
                I thought so as well. My 2 70's have it. Lectric limited harness doesn't have it, and insists 70 didn't have it. No info one way or the other in my 6th edition tim/jg
                Btw, mid June and early July cars
                • Mark E.
                  • April 1, 1993
                  • 4498
                  Check the CSM diagram. It shows connections.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Dennis D.
                    • March 1, 2000
                    • 1071
                    If you mean here, I'm not seeing it. Schematics are not my strong suit
                    • Mark E.
                      • April 1, 1993
                      • 4498
                      [ATTACH=CONFIG]122240[/ATTACH]
                      [ATTACH=CONFIG]122241[/ATTACH]
                      [ATTACH=CONFIG]122242[/ATTACH]
                      Okay, I take back my last comment. That's what I get for going by memory instead of looking.
                      Now I need to look at Doc Rebuild's diagram.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Dennis D.
                        • March 1, 2000
                        • 1071
                        Haven't had anyone say they have a harness without the pigtail. I don't know where to go besides lectric limited.
                        • Gary B.
                          • July 31, 1979
                          • 926
                          My 70, Vin 14,544, a July 5th built car, has the extension, which plugs into the harness near one of the wire loom fold-over tabs. First picture.
                          My 71, also has the extension. It's a November 25th, 1970 build car. Very similar location.
                          I have access to an early 70, I'll look at it tomorrow.
                          Gary Bosselman
                          • Mark E.
                            • April 1, 1993
                            • 4498
                            Corvette Central sells the pigtail:
                            https://www.corvettecentral.com/c3-6...harness-663167
                            Maybe the also sell the complementary connector you can add to the engine harness.
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                            • Dennis D.
                              • March 1, 2000
                              • 1071
                              Thanks Gary. Same location as my 2 cars.
