Have an issue with my '66 M21 I have not run into before. I adjust the shifter, (lining up with a home-made gauge) and neutral position and gear engagement is fine. However during a short drive the shifter slips out of neutral position adjustment. I readjust, short drive same result
I have been into the transmission twice. First for bearings and synchros and a second time to renew the main drive gear and idler shaft to eliminate a gear whine. During both transmission teardown, I saw no issue with shifter forks or slides, but I didn't have any specifications on wear limits either. This issue has been with the car since before 9th first transmission teardown.
Before I start tearing things apart again (without a plan) I'd like to know if anyone has run into this issue in the past or has suggestions.
Joe
Joe
