I have a 1966 427-L72 425 hp. Non altered.
The carb is a Holley # 3886101-E1, List 3247 dated 6-3-4 (March 4, 1966)
Metering block 4901-3247, 6R3551B-4519.
The intake is completely stock as is the the engine.
The car runs fine with no issues except the idling speed of the carb after warm up.
The idle is set to the factory settings and remains there until driven for a while and then the idle will
go to approx 1000 RPM and stay there until the next cold start up. Mind of its own.
Return springs, cabling, firewall opening etc were all checked out with no binding or other issues.
I can push the pedal down real fast when stopped but the carb idle speed still stays at 1000 rpm.
A few times I had to stop and turn the idle down but the problem still exists. The main problem is that when I turn
the car off it will sit and "diesel" for awhile.
Has anyone ever had this problem or have any suggestions of what it might be.
