1966 convertible top frame / rear bow question.
Re: 1966 convertible top frame / rear bow question.
Wayne, I'm wondering if their "Z" bracket wasn't bent right?
I found this file photo for reference.
Screenshot_20240617_061952_Chrome.jpg- Top
My other thought....
If your car was originally Hardtop only, if someone added the soft top, they may have installed the rear latches in the wrong location.
If someone can get a measurement from rear bolt to rear edge of decklid, this would verify if that was the case.
Rich- Top
Wayne,
My 1966 conv. top is assembled, but I attempted a measurement of the large forward hole in the bracket to the forward threaded hole in the bracket that a countersunk screw is in. My measurement is 1.950"
Ken- Top
It does look like the z bracket angle is different on my rear bow.- Top
Wayne, ok, good. I just wanted you to rule that possibility out.
It appears your problem lies in those Z brackets. I'd entertain removing the frame and bending them, if mine.
Rich- Top
hi wayne,
this is probably too little too late ... but fwiw, my 65 doesn't have extension brackets for the rear bow. my thought was the problem is with the rear bow they sold you. when GM built these cars they didn't use extension parts. everything you confirmed in your posts points to that bow. i'm with you on your thought symptom but not the cause. hope you have gotten a bow that's correct.
regards,
steve chaney- Top
