1966 convertible top frame / rear bow question. - NCRS Discussion Boards
  • Wayne L.
    • January 27, 2023
    • 36
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 1966 convertible top frame / rear bow question.
    Wayne, I'm wondering if their "Z" bracket wasn't bent right?
    I found this file photo for reference.
    • Wayne L.
      • January 27, 2023
      • 36
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        My other thought....
        If your car was originally Hardtop only, if someone added the soft top, they may have installed the rear latches in the wrong location.
        If someone can get a measurement from rear bolt to rear edge of decklid, this would verify if that was the case.
        Rich
        • Wayne L.
          • January 27, 2023
          • 36
          • Kenneth F.
            • September 30, 1988
            • 282
            Wayne,
            My 1966 conv. top is assembled, but I attempted a measurement of the large forward hole in the bracket to the forward threaded hole in the bracket that a countersunk screw is in. My measurement is 1.950"
            Ken
            • Chuck B.
              • August 31, 1987
              • 121
              • Chuck B.
                • August 31, 1987
                • 121
                It does look like the z bracket angle is different on my rear bow.
                • Wayne L.
                  • January 27, 2023
                  • 36
                  • Wayne L.
                    • January 27, 2023
                    • 36
                    Chuck, thanks for the photo. This confirms my latches are factory correct.
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11302
                      Wayne, ok, good. I just wanted you to rule that possibility out.
                      It appears your problem lies in those Z brackets. I'd entertain removing the frame and bending them, if mine.
                      Rich
                      • Steve C.
                        • June 1, 2021
                        • 35
                        hi wayne,
                        this is probably too little too late ... but fwiw, my 65 doesn't have extension brackets for the rear bow. my thought was the problem is with the rear bow they sold you. when GM built these cars they didn't use extension parts. everything you confirmed in your posts points to that bow. i'm with you on your thought symptom but not the cause. hope you have gotten a bow that's correct.
                        regards,
                        steve chaney
                        • Wayne L.
                          • January 27, 2023
                          • 36
                          • Steve C.
                            • June 1, 2021
                            • 35
                            sounds good Wayne...hope things come together for you. i'll be interested to hear how it went
                            steve
