/63 SCW - Wire from Starter to Coil - NCRS Discussion Boards
  • Norm B.
    • 360
    I need to replace the wire from the R terminal of the starter to the + connection of the coil on my 63 340 hp car. If I am reading the wiring diagram correctly it should be a pink 18 Ga. wire. To me 18 Ga. seems to be a little light for the task it has to perform. Is this correct or am I reading the diagram incorrectly?
    Golf is for those who can't play​ hockey.
  • Peter H.
    • April 1, 1980
    • 223
    Re: /63 SCW - Wire from Starter to Coil
    Hi Norm. I Just Checked My 63 Shop Manual And I Read It Using 18 Gauge Pink Wire. I Replaced Mine With 18 Gauge Wire Several Years Ago
    Your Good To Go. Peter
    • Norm B.
      • 360
      Thanks Peter. That's what I will use. Norm
      • Mike E.
        • February 28, 1975
        • 5134
        What exactly is a 63 SCW? I know what a 63 SWC is, but fill me in.
        • Norm B.
          • 360
          An SCW is what you get when you hit the key to post a new thread without proofreading. I was wondering if anyone was going to call me out on that one but it was too late when I noticed it.
