64 Conv. Rear Harness Routing - NCRS Discussion Boards
  • Ron L.
    • July 31, 1998
    • 111
    See AIM Sect. 12 Sheet C4.00 - in the lower left hand corner of the illustration - as the harness reaches the firewall and turns upward there is a reference of COVER ASM. Does the harness go between the body and the kick panel, or does it enter the lower oval hole in the door post and come out of the upper oval hole and then to the connector from the instrument panel? Too many years since I took out the old harness. Thanks in advance for any help.
  • Don H.
    Moderator
    • June 16, 2009
    • 2236
    Re: 64 Cone. Rear Harness Routing
    Ron,,I don't have your answer, but I can offer the AIM page.. Someone should be able to help.
    • Ron L.
      • July 31, 1998
      • 111
      Thank you Don - yes, I have the complete manual - that is why I was able to cite the section.
