C3 Frame Stamps - NCRS Discussion Boards
C3 Frame Stamps
  • Tim S.
    • May 31, 1990
    • 697
    C3 Frame Stamps
    Can anyone tell me the significance of these frame stampings? I am trying to help a fellow out on his 70 LT-1 that is needing frame repair / replacement.
    • 11608
    Re: C3 Frame Stamps
    Is this your 70 in the pictures? It surely doesn't look like a frame needing repair.
    • Tim S.
      • May 31, 1990
      • 697
      Re: C3 Frame Stamps
      It is Patrick. I posted my car for a visual reference of the stamps. Thankfully this car does not need a frame
      • Mike E.
        • February 28, 1975
        • 5134
        Re: C3 Frame Stamps
        Tim, I can't tell you about the significance of those stampings, but I can tell you that they are already on frames '62 and earlier. Good to see you at Bloomington!
          • 11608
          Re: C3 Frame Stamps
          I can't recall if they're a vendor stamp, or a part reference stamp that A. O. Smith used in assembling the frames. However, they all have the same numbers in the same locations.
          • Tim S.
            • May 31, 1990
            • 697
            Re: C3 Frame Stamps
            Likewise Mike! It's been a while.....that's for certain!
            • Tim S.
              • May 31, 1990
              • 697
              Re: C3 Frame Stamps
              I did see a -70 on a different one
                • 11608
                Re: C3 Frame Stamps
                Not the same number everywhere, but each corner gusset is -10, for example. I've seen other number on other pieces.
                Think of your Ikea furniture having the pieces numbered.
                • Eric S.
                  Infrequent User
                  • November 22, 2010
                  • 7
                  Re: C3 Frame Stamps
                  Those are inspection stamps on an original frame.
                  • Mike E.
                    • February 28, 1975
                    • 5134
                    Re: C3 Frame Stamps
                    • Eric S.
                      Infrequent User
                      • November 22, 2010
                      • 7
                      Re: C3 Frame Stamps
                      Hi Mike. I might be full of beans and I understand that we're talking about a C-3 but I was looking at the stencils on my C-2 (65). In the manual there is a notation about inspection stampings " Original cars have been observed with a 1/2" circular inspection stamping with a 2 digit number inside on both sides of the frame bottom corner triangular reinforcements" The manual also has a picture which looks a lot like the ones in the post. Again this is on a '65 but they may have continued to use them.
