Want to borrow or rent 62 4-speed shift lever gauge block - NCRS Discussion Boards
  • Robert I.
    • July 31, 2004
    • 164
    I need the shift lever gauge block for a 62 4-speed.
    A place in Canada has them, but wants $55 for shipping.
    A place in Michigan is out of stock.
    Anybody have one I could borrow or rent?
    ____________________
    Bob Immler
  • Terry D.
    • May 31, 1987
    • 2690
    Re: Want to borrow or rent 62 4-speed shift lever gauge block
    Are you talking about a device to line up the shift rods properly?
    • Dennis C.
      • June 30, 2002
      • 884
      The dimensions for this aid is given in the 1961 passenger car Chevy service manual, which is another must have for working on your car. The tool is easy to make.
      • Harry S.
        • July 31, 2002
        • 5258
        When these tools first came out, I bought one. I asked an old-time mechanic at a Chevy dealership how to use it properly. He said, use it initially to make adjustments, then take it out and feel with your fingers if everything is aligned. The tool assumes all transmissions are built the same, some are different. By feeling, you may decide to move one slightly as a final adjustment. Just me 2 cents.
        • Mark E.
          • April 1, 1993
          • 4498
          T10 may be different, but with a Muncie:
          1- Disconnect shift rods
          2- Visually line up shifter and rod levers to neutral position instead of using a tool
          3- Adjust the rod lengths then reconnect without clips
          4- Check that the shifter moves feely left/right in neutral gate
          5- Repeat as needed then add rod clips
          6- Check operation through gears. Reverse may need additional adjusting
          If you have it, adjust back up light switch too.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Robert I.
            • July 31, 2004
            • 164
            So I made the gauge and gave it to the mechanic. He says "neutral is now neutral" but that it jumps out of gear.
            I'm going to try to drive it on some back streets tomorrow.
            This car hasn't been driven in 35 or 40 years. trans has not been taken apart. It was drained and I put in new gear oil. Could the old oil have become "gunk?"
            Bob Immler
            • Mark E.
              • April 1, 1993
              • 4498
              Did it jump out of gear before the linkage adjustment? I ask because this symptom usually indicates transmission wear rather than the shifter out of adjustment.
              If it jumps out of a specific gear, that points to a synchro or maybe worn gear. That gear will usually be difficult to shift into as well, especially when downshifting.
              If it jumps out of all gears, it could be all the synchros are worn (less likely) or a wobbly mainshaft due to a bad pilot bushing.
              I'm not a transmission expert but that's my personal experience. Maybe a transmission guru will chime in.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Robert I.
                • July 31, 2004
                • 164
                A mechanic at the shop made a gauge for me using 3D printing.
                Bob Immler
