Looking for a pic of the above item/s. Thank you. J.J.
1964 odometer bracket orientation and cable routing
Re: 1964 odometer bracket orientation and cable routing
Found this diagram. Hope it helps.
2nd pic is from the '65 A.I.M.
Under dash column brackets and u-bolt.jpgDave Zuberer- Top
Will these help? Note my oil line has been changed a number of times however always took great pain to run it the same way, ie through the parking brake bracket hole- Top
