Greetings,
I'm attempting to resolve a little issue with my manual C2 steering which concerns the fact that it is a little twitchy when negotiating corners/curves. Best way I can describe it is to say that if the car is set up properly for the curve all seems well but if a slight mid-curve correction is attempted the car seems a mite unstable/twitchy. Now, given that the car is not driven often this MIGHT be due to the fact that in comparison with modern rack and pinion steering, these old Corvettes are not as predictable by a fair margin. However, at present, my steering seems to suffer more than I recall these cars doing.
Presently I'm in the process of replacing the ball and socket link between the pitman arm and relay rod with a kit from Zip. Additionally, recently I've replaced lower ball joints and all four lower control arm bushings (and upper bushings). My question concerns lash in the gears and races in the box. With the pitman arm disconnected from the relay rod there is a perceptible amount of play in that the pitman arm can be moved about 1/16 inch before the slack is taken up. Stated another way, given that the pitman arm is about 5 3/4 inches long between attachment points at the pitman shaft and the ball socket at the relay rod, this approximate slackness amounts to about 0.5 degrees. I'm eye balling the 1/16 inch and thus possibly the angular movement could be a little more than 30 minutes (1/2 degree). Is this normal or should there be No slack (lash) whatsoever? I've read instructions on the use of a small (inch/pounds) torque wrench to measure the force necessary to move the steering wheel/shaft but have yet to locate that small a torque wrench. Again, is a little looseness between input and output shaft indicative of a a problem in the steering box or is this normal?
What else might be causing my concern as to the loose feeling I have [there is nothing to compare with rack and pinion steering and I salute the English for coming up with it--first used, I believe, on MGs in the '50s]? I know it could be tie rod ends but they certainly "feel" tight. My alignment is about 1 1/4 degrees positive caster and 1/2 to 3/4 degree positive camber. Toe about 3/16 inch total. As to the rear, the right side could stand to be toed in by moving 1/32" of shim from inside to outside of trailing arm. Rear camber is about 1/4 to 1/2 degree negative. (I believe on the right side moving 1/16" of shims would likely be too much toe-in.) I say "about" because this is my using a caster/camber gauge and a string line for toe. I'm hoping to replace all worn components myself before paying for alignment and/or not being satisfied with what I can do myself.
Bill
Bill
