Well, I couldn't take the noise any longer and had opinions of the noise from a wheel bearing, rear end and even transmission from some knowledgeable guys. So, I propped up the rear keeping the half shafts aligned and it sounded like a wheel bearing on both sides. It really sounded like metal to metal. I took it a step further and pulled the half shafts off. Both wheels when spun were very quiet! They were rebuilt 3k ago as well the rear gears. So, I now know for sure it is the rear. I then discovered that the left half shaft was sticking out, so I pulled on it and obviously the C clamp is gone and of course floating around somewhere.
The car had sat for 8 years after restoration. There was no noise in the rear at all, but the rear was ratcheting BADLY! I changed the fluid and posi additive and proceeded to do a figure 8 when there was a loud pop, louder than the typical ratchetting. Not sure what happened I visualize the C clamp getting somewhere it should have not been. We'll be pulling it and advise what is found
