I am working on a 67 roadster I just bought. I'll give you an overview of the car, as it may contribute to the problem I am trying to solve. Relatively nice driving car with 52k miles. All stock, no mods. Nice clean rust free frame, no accidents, etc. New Goodyear Power Cushions all the way around. The car drove reasonably well, but have driven others that instill much more confidence. The car would be a bit squirrely under hard braking and acceleration. Furthermore, the car had a vibration in it at 60mph that I just could not get out. I am fairly confident no one has been in here before.....it all looks to be factory issue work. In other words, the correct and original toe shims, bolts, hardware, etc.
That all having been said, the right side TA bushing had some slop to it as did the right side spindle bearing. I've been here before, so the best thing to do is to rebuild the arms. I always get a noticeable improvement in rebuilding the arms. No biggie there.
My question is this.....
After disassembly (keeping the original toe shims arranged in their respective locations) the left side is toe'd out. The right side is toe'd in. The steering wheel is off a bit as well. I have not measured anything as of this point. I must say, I have not observed a shim arrangement like this before. Am I leading a sheltered life? Has it been observed where the factory just screwed it up?
I understand the car needs to be aligned after all is reassembled. I'd prefer to use the correct shims after all is said and done. The alignment shop has done, and will do these alignments for me. You can see they are not crazy about it. I live in a remote area so my choices are very limited. As a result, I always try to get as much BS out of the way in order to help the process along.
I could just reinstall the shims the as they were previously arranged and let the alignment shop have at it. I ask the question simply to minimize how much redundant labor this may require. No, I'm not lazy. I figure it's easier to ask a few questions first.
Thanks in advance,
Tim
Thanks in advance,
Tim
I have the link saved from that auction. I admire the detail of the car, as well as the eye for preservation
