Are there more correct heater hose for a �66?
The old number at Paragon was 1713K. The older stuff was LESS RIBBED THAN 19024K, BUT PRONE TO FOGGING GRAYING. I have a CLOUDY SURFACE on the older set. I have the ribs you observed on the new set. ...About the last item I bought at Paragon.19024K.
Revision: Normally, a search for Paragon numbers on "CC" works, but today I failed to make either of these two Paragon numbers reference the kit you bought...https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
