Would the the headrest option (A82) have been available on a 66 with a VIN in the low 1700s or did they become available later in the production run?
1966 Headrests
Re: 1966 Headrests
Hello Mike,
I'm not sure if you are asking about the body build date, or VIN # sequence, but I will share both you.
My '66 is a Coupe with a Body Build date A-1457. and the last 5 of the VIN are 07839. The car was built on December 8,1965. It does have the A82 option, and I have all the original paperwork including the window sticker, invoice and Warranty booklet to validate the options on this car.
Hope this helps!
Eric Patty #8355- Top
Re: 1966 Headrests
Mike - I was under the impression that the A82 Headrest Option was available throughout the 66 model year run. My 66 Mosport Coupe has headrests on Dark Green interior and it's VIN is in the 54XX range.Mike T. - Prescott AZ.- Top
Re: 1966 Headrests
Mike J- I have some paperwork for a 1966 that started the order process on 9-15-65.
The 'EARLY' 66 order form didn't have the headrest seats, so it was hand written in.
Mike T- The paperwork on this car went back & forth to Zone (due to BB option changes)... the VIN ended up in the 54XX range.
(too bad itz a different color scheme... you had me double checking)- Top
