Anyone have any tips or tricks to this install? I have Corvette Rubber w\ strip nos clips and Keen Corvette longer clips. Thanks Bob
1963 coupe rear window installation tips- tricks ?
Re: 1963 coupe rear window installation tips- tricks ?
Joe, Thank you for your reply. Did you use original or reproduction weatherstrips ? Also on the back side of the molding where it clips on how far in did you place the clips? Thanks again Bob- Top
Bob, I get my rubber from Corvette Central. There should be small indicators on the body for where the clips go. If someone sanded them off check the AIM for positions. I add an extra at the roof curve and at the rear deck curve. Those area are always trouble.
Good luck.- Top
Joe, Thanks again. Yes some of the indicators were sanded off . I do have a AIM so I will look at it . Can I call you if I need more info if so when is a good time?
