Turn signal - NCRS Discussion Boards
Turn signal
  • Bill M.
    • 1317
    Turn signal
    I finally gave up on my front right turn signal failure. I just replaced the turn signal switch. New from electric limited. Signals all work great. But my horn is now energized I had to pull connector off of the relay. I checked my steering re assembly and all looks right. Any ideas ? Thanks
    • 6940
    Re: Turn signal
    Bill since the horn button works on a ground. Maybe check you horn button under the chrome cap.sometimes the button can ground out on the steering wheel, look close.
    • Bill M.
      • 1317
      Re: Turn signal
      Thanks Ed will do. It is a tele column.
