1964 questions (simple) I hope - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1396
    Re: 1964 questions (simple) I hope
    Originally posted by Rich Giannotti (38594)
    Friends who know next to nothing about Corvettes except that they want one. They claim they don’t care about the numbers thing. They just want a good driver coupe. They have asked me for help and they are looking at a 64 that looks sketchy at best to me. It has a 327 in it but the numbers on the pad aren’t anything I’ve seen but I’ve never looked at a 64 stamp pad. Picture attached.
    Next I have a picture of the VIN tag. It’s attached with spot welds which I think is right for 64. Opinion?
    tThere are many more things I see in pictures that will make me advise them to keep looking but it’s local and they want to look. I have advised them to join NCRS, buy some books and slow down.
    Rich
    Rich-----
    ABSOLUTELY NOT an original stamping. First, this was stamped using individual stamping dies and not a gang-style stamp. The factory did not use individual dies. Second, the "T" prefix would indicate a Tonawanda-assembled small block. No Tonawanda ASSEMBLED small blocks were ever originally installed in Corvettes (although a small number of Tonawanda CAST small blocks were used).
    I do note an "F" prefix stamping on the lower right. This is likely what remains of the original engine code stamping. The irregular "T" prefix stamping might just be a random stamping done to obliterate an original VIN stamping (perhaps because the engine had a stolen vehicle's VIN originally stamped there).
    • David H.
      • June 30, 2001
      • 1485
      Rich
      Trim Tag Photo?
      Dave
      • Rich G.
        • August 31, 2002
        • 1396
        • Owen L.
          • September 30, 1991
          • 838
          [ATTACH=CONFIG]124069[/ATTACH]
          Rich
          Joe, isn't the T-sequence the VIN designation of the assembly plant the engine was installed in? Where Corvettes have an S in the VIN for St. Louis, the T represents Tarrytown, NY (a standard passenger car plant for Bel Air, Impala, Biscayne, etc.).
          Here's a '65 Chevelle pad from Chevellestuff.net that looks similarly wonky to the engine above.
