Ignition lock - NCRS Discussion Boards
Ignition lock
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Ignition lock
    Hello All,
    Is the ignition lock on the steering column for a standard column the same as for a tilt column on a C3? I am not referring to the ignition switch which is located further down on the column but the lock with the key.
    Jeff
    Re: Ignition lock
    Originally posted by Jeffrey Salz (13182)
    Hello All,
    Jeff
    Jeff------
    The lock cylinder assembly is the same for both standard and T/T columns for 1969.
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Re: Ignition lock
      Joe,
      Thanks for the quick response! I was hoping you would see this and chime in.
      Jeff
