Speedometer repair issue - NCRS Discussion Boards
  • Gary G.
    • July 31, 1998
    • 51
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Speedometer repair issue
    remove the speedo cable from the head of the speedometer , raise tires off ground, put it in gear and observe if the cable within the speedometer cable assembly you just removed is rotating. if not, you probably need a drive or driven gear at the tranny tailhousing. mike mccagh
    • Gary G.
      • July 31, 1998
      • 51
      • John F.
        • March 23, 2008
        • 2395
        I would think yes.
        • Gary G.
          • July 31, 1998
          • 51
          • Frank E.
            • May 31, 1986
            • 189
            Ir's not that bad a job. However, there is a grease seal in the bullet. Be careful not to lose it....
            Frank
            1966 Milano Maroon Roadster
            2004 CE Z06
            • Gary G.
              • July 31, 1998
              • 51
