68 Fan Shroud - Need AIM page - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I'm repairing a fan shroud for a friend. It was in a 66 big block, but from all the researching we have done it appears to be a 68 big block shroud.
    Per the 66 and 67 AIMs, the three part of the shroud for 66 and 67 were the same with the exception of the Right (passenger) side.
    I have seen a couple of eBay listings that claim to be 68 one year only listing the same part numbers as the 67 AIM (top 3888269, left 3886887, and right 3911110).
    I have seen reference to an early and late 67 shroud. If this is true, I assume the Early would be the same as 66.
    I would appreciate it if someone with a 68 AIM could post a picture of the shroud. It should be in the L36 section of the AIM and somewhere around page A3.
    Thanks very much,
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: 68 Fan Shroud - Need AIM page
    Don, 1968 AIM L36 shroud page A13. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Donald H.
      • November 2, 2009
      • 2580
      Thanks Gary. Exactly what I was after
      Don Harris
      • Donald H.
        • November 2, 2009
        • 2580
        The 68 shroud parts are definitely different than 66 and 67.
        Don Harris
        • Gary B.
          • July 31, 1979
          • 926
          Early 68's suffered from severe cooling issues. Early L36 fan shrouds were metal, with a single rib. AIM L36, Sht A12, with no changes records indicate that. See Below.
          Sheet L36 Sheet A11, shows a metal fan shroud with 2-ribs.
          Sheet L36, Page A11 was revised 12-1-67 which shows a plastic fan shroud with a hole in the upper left corner.
          Sheet L36, Sheet A11 dated 1-3-68 shows the hole removed.
          The following 5-scans illustrate what I think was the progress of fan shrouds. My April 1 build L72 uses the final version.
          Gary Bosselman
          • Donald H.
            • November 2, 2009
            • 2580
            Thanks Gary,
            Very informative. What we have is definitely a 68 and we removed it from a 66!!
            Don
            Don Harris
