1969 Engine Mounts - need some help / advice - NCRS Discussion Boards
  • Kevin S.
    • January 5, 2011
    • 255
    #31
    Re: 1969 Engine Mounts - need some help / advice
    Hi Patrick,
    I did not know that a reproduction later style bolt kit existed? Where might I find that?
    Today, per Joe's additional detailed size and finish, I went back to the Bolt Depot website and ordered (2) 7/16" - 14 x 4 1/2" long, grade 8, hex head zinc-plated bolts. I can strip these and manganese phosphate (black) finish these to correct finish even though they are 1/16" longer and they do not have the pilot tip. I might be able to modify the tip and create a pilot tip with my Dremel. The Bolt Depot did not have bolts with a "pilot tip". They (Bolt Depot) directed me to McMaster-Carr and thought they might have a pilot tip option but they do not offer "pilot tip" options either.
    Bolt Depot did have (2) "Stover type" prevailing torque lock nuts, grade 8, zince finish, 7/16" - 14 thread count so I bought those. These are an exact match to what Joe described in his details.
    Still have a question on the Stover self-locking nuts? Should I use blue threadlocker, anti-seize, or just leave them alone and torque to spec based on AIM P. 201, UPC 6, B3, Engine Front Mounting, item number 2, PN 272876 Nut, torque spec 25 - 35 Ft Lbs. My intuition tells me to use the blue threadlocker even with a Stover type prevailing self-locking nut.
    Kevin
      • 11608
      #32
      Originally posted by Kevin Saxton (52665)
      Hi Patrick,
      Kevin
      https://www.corvettecentral.com/c3-6...eadmark-303363
      • Leif A.
        • August 31, 1997
        • 3607
        #33
        Not sure the length of the bolts from Corvette Central, but the ones from Zip are 4 7/16" pilot point, "A" headmark, black phosphate, Grade 8.
        Shop for 1970-1982 Corvette Engine Mount Frame Bolts (Correct) at Zip, your source for C2 & C3 Corvette engine mounts & reproduction mounting hardware. (GM Part 399803, 9422299)
        Leif
        • Kevin S.
          • January 5, 2011
          • 255
          #34
          Hey Leif & Patrick,
          Thanks for the links and info on the long through-bolts for the locking-style engine mounts. Corvette Central and Zip are identical 7/16" - 14 x 4 7/16" black phosphate, pilot tip, "A" head marks, grade 8 bolts.
          Thank you.
          Kevin
