C2 St.Louis Production Floor Basement? - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2027
    Most descriptions of the factory assembly line mention storage/assembly areas in the basement.
    Galloway/Hinkley reference storage, zinc chromate, rear subassembly, and ?
    Tony Avedisian, Gregory Keith and Marty Fowler mention the N03 option, others say nothing was done in basement.
    So just what was in or done on a C2 in the basement?
    References to above people were taken from other NCRS posts, sorry for spelling or wrong references.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17549
    Re: C2 St.Louis Production Floor Basement?
    Consider that John Hinckley was at the St. Louis Corvette plant in 1966 & 1967
    Excerpts referencing St. Louis Corvette plant basement work from John Hinckley's 2011 Seminar - Midyear Corvette Assembly Process
    - Underbody panel sent up to main floor level and loaded/bolted to pedestals on steel body build truck.
    - After the birdcage was completed downstairs, it was sent up to the main floor in the Body Shop and was loaded/bonded/riveted into the underbody, forming the foundation for the rest of the body build.
    - Cowl & Dash subassembly (including the female hood latches and cross-cable), also built up downstairs, was loaded and fixture-located to the underbody and build truck and bonded in place.
    - There was no raw-metal prime or paint facility in the Corvette plant other than the small crude zinc chromate primer system in the basement used for the birdcage.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Alan D.
      • January 1, 2005
      • 2027
      And from that same Seminar, page 12
      Install rear suspension module (subassembly from basement
      included the suspension crossmember and cushions, differential and
      nose bracket, half-shafts, trailing arm assemblies, strut bracket and
      rods, and rear spring with the ends free)
      • Alan D.
        • January 1, 2005
        • 2027
        So, does everyone agree that a basement existed and some assembly was done there?
        At present, John Hinckley is our reference from his 2011 Seminar - Midyear Corvette Assembly Process
        These are:
        1 underbody panels, 2 birdgage, 3 cowl & dash, 4 chromate primer, & 5 rear suspension
