I am looking for the configuration of the power brake hose on a 1967 big block. I have the hose going parallel to the firewall straight across into the power booster valve. Does it cut across the front of the distributor and behind the carburetor? I am assuming that the vacuum hose adapter that sits on the manifold is pointing directly to the fender of the car on the left side. That would make it go straight. Could somebody please post a picture just to make sure that I am placing it correctly.
1967 power booster hose orientation
Re: 1967 power booster hose orientation
Keith,
Picture of my '67 L79...BB is routed the same. You want to be sure to stay clear of the accelerator linkage.Attached FilesLeif
Top Flight 2017 Lone Star Regional- Top
Looks like it's straight off the manifold fitting and over the accelerator rod. (J50, A3)
Screenshot 2024-12-18 at 5.24.39 PM.jpg- Top
How about this...Attached FilesLeif
