1965 Corvette Turn Signal Issue - Aftermarket Switch Problems - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 375
    My 1965 Corvette was experiencing a turn signal issue where both left and right indicators would flash simultaneously, even when only the left signal was activated.
    After troubleshooting, I determined the problem originated with the aftermarket turn signal switch in the steering column hub. Upon inspection, I found that the spring contacts on the aftermarket switch were misaligned compared to an original switch. See photos.
    To rectify the issue, I replaced the aftermarket switch with an original good unit. This resolved the erratic turn signal behaviour.
    This experience highlights a potential issue with the quality of some aftermarket turn signal switches. Has anyone else had problems with these aftermarket switches?
    If you encounter similar issues, I recommend checking the alignment of the contacts on your switch.
    In my case, reverting to the original switch successfully resolved the issue. I hope this information proves helpful to other Corvette owners.1.jpg
  • Michael G.
    • November 12, 2008
    • 2155
    Aftermarket electrical components in general don’t comprehend the rigorous testing done on the originals. Springs and contacts are particularly bad. The headlight rotation switch as well as the on/off switch are similar examples of aftermarket parts that fail almost immediately. Get an original, if you can.
