I have done a lot of reading of past posts going back 20 years in search of the proper information regarding the engine cooling fan for a 1967 small block with AC. The car I am working on has a 7-blade big block fan, which is not correct.
Those past posts indicate that by 1965 the 5-blade fan moved from a mushroom-shaped (or rounded) rivet to a flat rivet, and that for Corvettes they used 4 rivets to retain each fan blade.
The current 1967 Judging Guide, however, says “Air-conditioned Small Block fans were either one of two assemblies. Both have five blades with an overall diameter of 18" and use five mushroom head rivets to attach each blade to a reinforcement arm.”
Is the judging guide incorrect with regard to the configuration and number of rivets used in 1967 small block w/AC cars?
Thanks.
Thanks.
