Coil test values? - NCRS Discussion Boards
Coil test values?
  • Gary S.
    • July 31, 1992
    • 1628
    Coil test values?
    I am looking for the primary and secondary winding ohm test results for a Delco Remy 270 BR coil. I had to do some digging to even figure out how to test it (found that) but actual ohm values for individual DR coils eludes me.
    Anyone have a source for that ? If all else fails I can plug it into my car but that doesn't help me if a potential buyer asks for the test results.
    Thank you again.
    Gary
    • 15610
    If that coil was OE for any model year the primary and secondary resistance should be listed in the applicable service manual. There might also be info in the applicable year AMA specs.
    Primary resistance is measured between the pos. and neg. terminals, secondary resistance between the center terminal and coil case.
