Hi All,
I've just installed my new refurbished carbs (done in Sydney Australia) and have an issue where the idle speed is around 1000rpm (with the accelerator cable and outer carb rods disconnected) unless I rev the engine quickly and hold the throttle linkage hard in the closed position. I can't adjust the idle speed using the adjusting screw, below 750rpm.
I feel its something binding but i'm not sure and haven't removed the carbs to see. I have included some pics below and have adjusted the idle (as best i can), then the mixture screws when i could get the idle below 900-1000 rpm. Once i got it to around 750 idle turning the mixture screws in would make the engine stumble on the drivers side and stop when turning in on the passengers side (still a left hand drive car).
I thought I would reach out to the experts to see if something in the pics was obviously wrong.
- The engine doesn't make any noticeable change if i cup my hand over the centre carb
- I have adjusted the bowl vent rod as it was binding on the actuating rod at the step
- I have checked and adjusted the fuel bowls, with only the front one being too high
- Timing is set in accordance with Lars's paper. 36 deg at around 2850 with correct VAC advance unit and VAC stopper at 12 deg
Any help would be greatly appreciated. I did have a popping from the side exhaust at idle but that seems to have gone since making the adjustments above. One other thing is, it smells like its running rich (no smoke), but not sure if this symptom points to an obvious reason for the high idle. Its really difficult getting tri Power help here in Oz but the company who did them are a Holley agent, but don't see many tri Power set ups.
Many thanks again and i look forward to your responses.
Grahame
Grahame
