Re: c2 pad stamp
Hi Stephen:
I'd say "so far so good" for what can be seen in your photo, but to get a better look you need to remove the paint. Use only a chemical paint stripper with no abrasion whatsoever, so that you don't scratch the surface.
One thing that people will want to see are the broach marks, which are fine parallel lines in the surface that were made by the machining process. You can see the broach marks in the attached photo of the pad on my car (believed to be the original factory pad).
By the way, other checks you should make on the block are the casting number and the casting date. These are located on the driver's side bellhousing flange and passenger side bellhousing flange, respectively.
Lastly, if you want to confirm that the trim tag is real and that the car's trim configuration matches the numbers on the tag, get a copy of Al Grenning's trim tag book from the NCRS book store. If you can't wait to get the book, one of us can at least check the trim number and exception code for you if you want. However, verifying that the trim tag itself is an original requires examining it under magnification.
Hi Stephen:
