71 454 Block Drain Plugs - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 474
    Can someone tell me what the drain plug on each side of the block should look like as far as any special markings, shape, etc. This is the plug just directly behind and below the rear lower motor mount bolt hole.
    Sheldon
  • Steven S.
    • August 29, 2007
    • 571
    Re: 71 454 Block Drain Plugs
    I have a '71 Chevelle LS5 and those plugs were just standard hex head with no special markings.
    • Steven S.
      • August 29, 2007
      • 571
      • Sheldon S.
        • March 1, 1999
        • 474
        Thanks Steve, does your chevelle have the motor mount heat sheild? Ifso, do you happen to have a picture of it or a description? I found one of a 350 SS car and am wondering if it is the same.
        Sheldon
        • Sheldon S.
          • March 1, 1999
          • 474
          Sheldon
          • Steven S.
            • August 29, 2007
            • 571
            Hi Sheldon. I do not have the heat shield, actually I don't even have the Chevelle , so I won't be of any help there. Steve
            • Steven S.
              • August 29, 2007
              • 571
              • Sheldon S.
                • March 1, 1999
                • 474
                Re: 71 454 Motor Mount Heat Sheild
                Does anyone have a picture of the left motor mount heat sheild or a really good description. I found a 71 heat shield off a 350 SS and am wondering if it is the same.
                Sheldon
                • Sheldon S.
                  • March 1, 1999
                  • 474
                  Sheldon
                    Sheldon-----
                    Dr. Rebuild sells an excellent reproduction of the motor mount heat shield used for 454's.
                      Sheldon-----
                      • Joe G.
                        • February 1, 2002
                        • 89
                        Sheldon,
                        Here is a shot of the shield on my 71 BB if it helps. I can get you a better picture if you still need it as the engine is now out of the car.
                        Joe
                        • Bernard S.
                          • June 30, 1992
                          • 56
                          Sheldon: There was an excellent article describing the big block heat shield even including a template to make your own in the Restorer a few years back
                          • Joe T.
                            • October 25, 2006
                            • 304
                            Hi Sheldon: Pictures from my '69 L-36 427. Aftermarket heat shield, but I presume this is what their supposed to look like...Regards,,,Joe
