zo6 ls7 rod bolts - NCRS Discussion Boards
zo6 ls7 rod bolts
  • Graeme B.
    • October 23, 2007
    • 213
    zo6 ls7 rod bolts
    Hi all,hope you can help me.I need to know the rod bolt torque values for assembling with new original bolts.Thanks in advance,Graeme from OZ.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: zo6 ls7 rod bolts
    Graeme from OZ, we are only supposed to consider Corvettes C4 and older on this site, but since you have such an interesting name, and I have the information at hand, I'm going to give you a freebie...
    Maybe this is not the easy answer you expected...if I were building an LS7, I would have to buy the complete Service Manual for myself. From the 2006 Covette Service Manual, Engine Mechanical - 7.0L, page 6-539:
    10. Install the bearing cap (103), bearing (104), and bolts (102).
    Tighten
    10.1 Tighten the bolts a first pass to 20 N-m (15 lb-ft).
    10.2 Tighten the bolts a final pass to 75 degrees using the J45059 (GM special tool).
    • Chuck S.
      • April 1, 1992
      • 4668
      Tighten
      • Dick W.
        • 10483
        Graeme is one of our members from "down under"
        Good day mate
        Dick Whittington
        • Dick W.
          • 10483
          Good day mate
          Dick Whittington
          • Graeme B.
            • October 23, 2007
            • 213
            Thanks Chuck.I didn't know about -up to C4.I'll keep my questions to my '69 L71.Cheers,Graeme.
            • Graeme B.
              • October 23, 2007
              • 213
              • Chuck S.
                • April 1, 1992
                • 4668
                Nice to hear from ya', Graeme. I hope my info was helpful...torque "by degrees" is not a familiar concept to me. Congrats on owning a Z06 "Downunder".
                • Chuck S.
                  • April 1, 1992
                  • 4668
                    • 15573
                    Some of us like LS7s
                    Try this link for C6 torque values:
                    http://forums.corvetteforum.com/showthread.php?t=1144462&page=2
                    See post #35
                    Good luck with your LS7
                      • 15573
                      See post #35
                        • 15610
                        It sounds like one of those designs that stretches the bolt beyond the elastic limit.
                          • 15610
                          • Chuck S.
                            • April 1, 1992
                            • 4668
                            Duke, is it possible the tensioning procedure as simple as 75 degrees rotation after the first stage torqueing to 15 ft-lbs? I'm wondering if you can just use a machinist's protractor if you don't want to buy the special tool.
                            • Chuck S.
                              • April 1, 1992
                              • 4668
