heater fan ground 1960 - NCRS Discussion Boards
  • Michael B.
    • March 31, 2008
    • 88
    hello,I haven't found the method of grounding heater fan motor I seem to recall a wire on housing mount screw but I can't seem to find it thanks, mike
    Re: heater fan ground 1960
    I thought the heater blower fan was grounded back to the cockpit's instrument cluster by way of the Bowden cable that controlled it...
      • Dennis A.
        • April 30, 1999
        • 1010
        Jack is dead on...make sure you use star washers on the control swith mounting to the console plate. Also on the black ground wire that leads from the back of the console plate...
        • Dennis A.
          • April 30, 1999
          • 1010
          • John M.
            • January 1, 1999
            • 1553
            The other thing you have to watch out for is some people will put the foam gasket between the T-stat mounting plate and the fan housing instead of on the engine compartment sdie of the plate. If this is done, it will insulate the fan housing from the T-stat mounting plate, which is where the bowden cable terminates. I have fixed a couple of cars like this by inserting a Tek screw through the inside of the fan housing into the mounting plate. This screw is hidden inside the fan housing, and it is way easier than pulling the entire heater assembly back apart!
            Regards, John McGraw
            • John M.
              • January 1, 1999
              • 1553
