Replacing trim ring clips
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Re: Replacing trim ring clips
Greg, I've pulled those out before. I first noticed that the clips moved freely between the two tabs. With a narrow flat blade scewdriver I carefully lifted the two tabs that holds the clips on. With needle nose pliers I slipped the nose of one side of the pliers into the clip loop opening and the other on the outside. The clips slipped forward toward the outer edge and cleared the opened tabs and with a counterclockwise twist they slipped out. After I replaced the broken clips with correct replacement clips they were a snap to pop back in. I used a finish nail set to reset the tabs that holds the clips in. I couldn't figure out how to get that inner retainer ring out without having to flair out the stainless crimped edge at least half way around. You may have to open the crimped edge a bit at each clip location. Otherwise take them to a metal plating shop and they'll do it while reworking them to remove dings and scrapes to put a show polish on them.
I used your method today. Not easy, but in the end effective. Brought an old very nice ring with a missing clip back to life. Thanks for sharing the info.
Ken- Top
