Does anybody have a picture of the splash pan where the fuel line comes out and attaches to the flex line? The more I look at mine I think it's wrong. Just don't want to take a step back. Thanks
'62 Fuel line
Re: '62 Fuel line
Sorry, no pictures. On my old-fashioned garage, the doors swing out. There's a mound of snow there, and I don't want to shovel it.
What do you mean by "wrong"? Are you concerned about where the end of the hard line comes out? The angle of the end of the line? The fitting? If the stock flex hose fits, it should be right.- Top
Re: '62 Fuel line
I have correct flex line and fittings and everything connects right. But the line comes out from under the splash pan while it's still paralell with the frame. I'm trying to convince myself it should not come out untill to the cutout at the end. I believe the flex line will still reach in that position. Thanks- Top
Re: '62 Fuel line
The fuel line runs inside the splash pan until the end of the splash pan. There is a clip 2" in front of the splash pan that holds the fuel line before it starts down and crosses the frame.
Hope this helps.
John- Top
