1963 split windshield molding clips - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: 1963 split windshield molding clips
    Sander,
    I can recall the rear window openings have raised areas in the fiberglass where the clips are to go so if my memory is correct it will be obvious. As far as the front, When I counted mine that came out I recall having more than what the book says. When I get home I will look and give you a count of the front clips on my car. 1963 also has that special clip at the top and bottom of the windshield pillar moulding and it slids into the moulding and then attaches to the regular clips.
    Also remember there are wide clips for the windshield where the metal windshield frame thickness is triple thick. It will be obvious when you look at the frame.
    • Jack U.
      • November 1, 2003
      • 212
      It's been a few years ago so I don't remember the number on the windshield but it was close to 18. (My windshield was replaced previously too.) I purchased my clips for the windshield and rear windows from Corvette Pacifica. I'm not a fan of Paragon due to the quality of some of their products.
      • Nick M.
        • September 30, 2005
        • 143
        Sander
        I am considering removing my split windows to replace the weathered rubber seal. Can you telll me how the stainless trim is removed?
        63 FI SWC, Top Flight 2006/2008, PV 2007
        69 Coupe, 427, 400HP w/AC
        72 LT1 Targa Blue Convertible - Duntov Award
        07 Z06, Black/Black - Daily Driver
