70 LT-1 T60 hd battery - NCRS Discussion Boards
  • Mike G.
    • July 31, 2002
    • 709
    did the lt1's have the t60 heavy duty battery like the ls5? i know they had the 61 amp alternator but dont know about the battery.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 70 LT-1 T60 hd battery
    The heavy duty battery was regular production option (RPO Code T60) available to anyone ordering a 70 Corvette...assuming they had the $15.80.
    Edit: My mistake...you're asking if it was standard equipment on the LT1. We'll have to wait for an LT1 expert.
    • Mike G.
      • July 31, 2002
      • 709
      ok thanks, just wondered if it was standard on the lt1 since the hd alternator was standard. looks like 165 people ordered it other than the 4473 people that got it with the 454
      • Kenneth B.
        • August 31, 1984
        • 2084
        My 70 LT-1 had a warrenty card & I have the battery. It's a R79. Car has 19000 MI. Got it from the original owner. Could be he replaced it. Who knows. What dose the JM say.
        KEN
        • Mike G.
          • July 31, 2002
          • 709
          jm said it was std on ls5 and option on the rest. i guess it was just that. mine has the hd battery also but not sure if it was original.
          • Chuck S.
            • April 1, 1992
            • 4668
            Originally posted by Kenneth Barry (7808)
            ...What dose the JM say?...
            I wish I had thought of that, Ken
            TIM&JG says heavy duty batteries standard on big blocks, optional (T60) on small blocks. Eventhough LT1 is a Mighty Mouse, I read that as being an option only on LT1s.
            • Chuck S.
              • April 1, 1992
              • 4668
              After all these decades, I'm certain it's not the one that came in it. If it's an R89W, it's either a repro, or it's an NOS dry charge battery that someone paid an arm and a leg to own.
              • Kenneth B.
                • August 31, 1984
                • 2084
                CHARLES
                TERRY M. should be in on this.I let him use my battery when he had his LT-1 judged back in the day.
                KEN
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  CHARLES
                  KEN
                  I'm pretty sure Terry will have something to add. Your battery wouldn't have to be a heavy duty battery, unless it is an R79W. I presume the standard battery was an R79S, using the same nomenclature as the later R89?
                  Since Terry has an early car, your original configuration battery would be perfect for his car, heavy duty or not, according to the TIM&JG. The real question in my mind is whether your battery is the ORIGINAL battery installed in St. Louis...if it is, then it's a miracle battery in my opinion.
                  My 70 LT-1 had a warrenty card & I have the battery. It's a R79. Car has 19000 MI. Got it from the original owner. Could be he replaced it...
                  This is really interesting to me...maybe it IS a miracle battery. You would think that later service replacements would supercede the R79 with the R89 that was used later in 70 model year production. Edit: Hmmm...maybe not if the terminals were different. Maybe Terry can explain exactly what you have in your car.
                  • Mike G.
                    • July 31, 2002
                    • 709
                    the battery is no good. its probably been bad for a couple of decades. the car has been stored since the late 80's the best we can figure.
                    • Gary J.
                      • April 1, 1980
                      • 1229
                      Should it not say HD Battery on the tank and window sticker if they are available and the real stickers?
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        Yes...If it's an extra cost option as the TIM&JG says for small blocks, it would be shown as a line item on those documents (T60).
                        If it WAS standard equipment for the LT1 as the OP originally asked, No, you would not see it itemized on the tank and window stickers.
                        • Kenneth B.
                          • August 31, 1984
                          • 2084
                          My LT-I coupe is SN 3893 19000 MI all paper work including window sticker. I bought it from the original owner in 1980.
                          KEN
                          PS this battery died along time ago. The thing was dead when I loaned it to Terry. Sorry I mislead you
                          • Chuck S.
                            • April 1, 1992
                            • 4668
                            KEN
                            Ken, my point in the last paragraph was that your battery was likely a replacement by the original owner during the time when the R79 batteries were still available from Delco. It's still a remarkable run even for a replacement battery.
                            If I remember correctly, there was a terminal thread size change in the the later R89 that would make the two batteries (R79/R89) not interchangeable (cable ends wouldn't fit)...if that is the case, Delco would have had to maintain replacement battery supply for both R79 and R89 until the original configurations of both batteries were discontinued.
                            • Kenneth B.
                              • August 31, 1984
                              • 2084
                              Thats what I said I was sure he replaced it but this guy was old when I bought the car. The T-TOPS were never out of the car. Maroon/Saddle. I bought the car in 1980
                              KEN
