I've got my interior removed, including seats, carpets, center console etc. I need to replace the shift boot. Before I do something stupid I want to check on the correct way to do this.
My shift boot does not appear to be removable by stretching over the revers lock out t-bar handle. It appears that I have to remove the shifter from the linkage. I started to remove the pin at the base that runs in the same direction as the driveshaft but it does not want to come out easily. The first 1/4 inch movement is easy but then it gets stuck.
Before I try to start pounding on it I thought I'd check on the forum to see if I'm doing something wrong.
Thanks in advance for the help
- Is the one pin I'm working with the only thing holding the shift lever to the linkage?
- The exploded view of the chassis service manual shows another pin running perpindicular the driveshaft direction. However it does not appear to be going into the shift lever. Am I reading that right?
(or some other p-word). I've attached a picture to show it.
