As far as I assume frame rust starts always from the inside and penetrates to the outside, isn't it?
If you discover that you have a bit more surface rust somewhere on the outside (however the frame is still solid) and remove it there is some minor recession compared to the other area around. This may only be a visual issue but how is this treated? Just paint it over?
Oliver
Oliver
). In exteme cases, general pitting corrosion may progress to "scaling" where your former frame (now rust) is delaminating into small "sheets" of ferrous oxide.
