C3 Tire Question - NCRS Discussion Boards
C3 Tire Question
  • Don L.
    • August 31, 2005
    • 1005
    C3 Tire Question
    Can give me guidance on tire dating?. I have a Goodyear Speedway white line tire with markings as follows: LR01598 and 223991-2. I understand that dating is indicated somewhere in these characters. Anyone?
    Don Lowe
    NCRS #44382
    Carolinas Chapter
    • 15573
    Re: C3 Tire Question
    Is there a - in that number string, or are you indicating a number you can not read? I have never seen a dash in the tire serial number string.
      If neither of those is preceded by "DOT", it would appear to be pre-1968. If either DOES have "DOT", they're not the final standard format, which would place the tire prior to May, 1971. In any case, you certainly don't want to drive on it.
      • Drew P.
        • June 30, 1977
        • 180
        Hello Dan,
        Is the tire mounted on a rally wheel? What are the wheel date code?
        What year Coevette do you have?
        Drew Papsun
        • Don L.
          • August 31, 2005
          • 1005
          Think I got it, guys. It seems L=1968, R=January 0=G'year, 1=Akron and the rest is coding/sizing info for the tire. This info tells me that it's too old for my '72. I was considering it for a spare only, and it is currently without a rim. Thanks again.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
