What 1984 parts need to be remove on the judging field? - NCRS Discussion Boards
  • Eric J.
    • March 1, 1980
    • 771
    Having my 84 chapter judged this weekend and I am curious on the parts (air cleaner etc.) that need to be removed specific to the 84. This is the first newer then C2 I have had judged so a little guidance would be appreciated. (note: I have read the JRM on this and it is vague so please don't tell me to start there) What tools do I need to remove said items?
    By the way the needing four letter search worlds makes me use a few of my own four letter words. Eric
  • Joe C.
    • August 31, 1999
    • 4598
    Re: What 1984 parts need to be remove on the judging field?
    Eric,
    You need a ratchet and socket (13/16", I think) to lower your spare tire cover.
    You might need to expose your distributor cap. On an '85, this requires a small torx socket. Not sure about an '84, but it probably is exposed by removing the air cleaner via the 2 thumb screws.
    Bring a can of "Carb-and-Choke" cleaner with a spray extender tube. You can use this if you couldn't get at your engine stamp pad to clean it.
    Joe
    • Eric J.
      • March 1, 1980
      • 771
      Joe, thanks.
      I am interested in knowing if I need to remove the complete air cleaner housing on the Crossfire. Not necessary on your TPI 85.
      • Ken S.
        Infrequent User
        • April 1, 1994
        • 3
        Yes you will need to remove complete air cleaner in order to see cross fire injection underneath.
        Ken Sleeper
        • Eric J.
          • March 1, 1980
          • 771
          Ken, Thanks. Just the 4 fasters I see at the throttle bodies? Eric
