1963 Booster vacuum filter/valve - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
  • Sander B.
    • March 1, 2005
    • 499
    Re: 1963 Booster vacuum filter/valve
    No one knows ??
    • Michael H.
      • January 29, 2008
      • 7477
      It's definitely the correct style. I suppose there may be subtle differences in some of these but the 63 is shaped exactly as the one in your picture.
      • Sander B.
        • March 1, 2005
        • 499
        ok Thanks Michael
        because the JM does not mention if it is with or without an 90 degree angle
        like you seen on later years
        • Michael H.
          • January 29, 2008
          • 7477
          Originally posted by Sander Van Ballegooij (43500)
          ok Thanks Michael
          The 90* valve was first used for the 64 model year. That's when the opening in the front shell of the booster was moved to the other/inboard side.
          • Sander B.
            • March 1, 2005
            • 499
            ah that makes sence
            thanks again
