67 Hood Hinge Bolts - NCRS Discussion Boards
67 Hood Hinge Bolts
  • Steve M.
    • October 22, 2006
    • 88
    67 Hood Hinge Bolts
    Please confirm for me that the correct bolts for the hood hinges are as follows:
    Hinge to hood- 5/16" x 1/2"
    Hinge to fender - 5/6" x 3/4"
    Both have indented hex head with flat washer.
    Re: 67 Hood Hinge Bolts
    Steve-----
    Assuming that you mean 5/16 x 3/4" for hinge-to-fender, you have it correct. The thread size for both bolts is 5/16-18. Also, you can use the longer bolts for both applications. No one will ever know.
    • Kent K.
      • December 1, 1982
      • 1139
      The originals on my '67 are marked with an 'E', grade 5 (?) with lines at right , left & bottom sides of the letter, recessed head with pinch point and captured washer, finished in zincad (whichever it was). All are 5/16" x 18 x 3/4" long.
      Kent
      NCM Founder - Member #718
      • Nick C.
        • August 31, 1998
        • 542
        Anchors Away... Re: 67 Hood Hinge & support bolts; one example?
