Hi;
I recent finished a complete overhaul of the brakes on my 1963. Basically everything is new with the exception of the original steel lines which were in decent shape. I even had the master cylinder sleeved and rebuilt. BTW the drums are new as well and have been cut just a bit to ensure they are completely round.
Two questions...
1) On the self adjusters. As installed (by me) they appear to be working properly. I get the "clicks" when adjusting them up and they do not permit reverse action without relieving the arm. While this is true, I cannot seem to get the pedal to come up even after repeated stops while going in reverse as per the shop manual. To get a higher pedal I have had to pull the wheels and manually adjust... Am I missing something here???
2) My right rear brake seems to be dragging. It runs HOT and I can smell it cooking after a short ride. I've backed off that adjuster but honestly it was not all that tight to begin with. Any ideas what might be causing this one wheel to drag.. Again, I did the assembly, using all new parts.. the other side is just fine.
Appreciate any help you guys can provide...
Two questions...
