c3 pressure bleeder - NCRS Discussion Boards
c3 pressure bleeder
  • James T.
    • May 31, 2006
    • 47
    c3 pressure bleeder
    I have replaced the rubber brake hoses on my 72 4 speed small block. After reading the extensive archives and having spent some time caliper bleeding, I ordered a Motive pressure bleeder. My question is will the pressure bleeder bleed the MC, or should I do regular bench bleed? Thanks, Jim
  • Stephen B.
    • April 1, 1988
    • 876
    Re: c3 pressure bleeder
    I've never used a pressure bleeder. Instead, I bleed an additional quart of brake fluid through the system. Never any problems.
    • Harmon C.
      • August 31, 1994
      • 3228
      When installing a new MC you should be bench bleed it. The Motive bleeder works great for me.
      Lyle
      • Lee S.
        • September 30, 2002
        • 156
        I have a Motive Pressure Bleeder also. Initially, I hated it. I could never get a good seal from the cover to the master cylinder. This resulted in not being able to achieve more than 5 lb psi of brake fluid leaking all over the engine compartment and garage floor.
        John Z. suggested throwing away the chains and J hooks. Instead, use a piece of 1/4" alumnium plate or steel plate that covers the entire pressure bleeder cover. Actually, I used a piece of 3/8" plywood. Next, use a BIG C-clamp to cinch down the pressure bleeder cover reinforced by the plate or plywood to the top of the master cylinder.
        This allows for a leak-free seal. Put 2-quarts (or less) of brake fluid in the tank. Pump it up to about 15 lbs psi and start bleeding at the Rt rear. What a pleasure to use this tool now.
        • Joel A.
          • September 30, 1997
          • 205
          Pressure bleeders are great! You still need to bench-bleed the master first, tho. The pressure bleeder won't be able to purge all of the air out of the master itself.
          Joel Adams
          1974 Coupe
          1985 Coupe
          "I know the voices aren't real...but sometimes they have some really kewl ideas...."
          • Lee S.
            • 156
            Thanks Joel. You are correct. I should have mentioned that I did not replace the master cylinder. In my situation, I was replacing calipers.
              Here's the setup I use instead of the hooks and chains - it's a 6"-long piece of 1-1/2" square aluminum tubing I had left over from another project, and a 6" C-clamp; works like a charm.
              • Jeremy D.
                • November 1, 1998
                • 323
                I used one of my grandfather's old wood clamps that he used when he built cabinets- I just cut off 4 of the 6 feet of pipe on the clamp, and used a treated wood 2x4 scrap to make the seal. The Motive Bleeder is the 2nd best tool in the toolbox!!!
                • James T.
                  • May 31, 2006
                  • 47
                  Thanks again to all, especially regarding the chains vs. improvising a better way to seal the rubber diaphragm. I used a 5/4x6-6" mahogany I had in the shop and a 6" c clamp. Way easier, quicker and dryer than using the chain. Bleed all six valves and got a hard pedal in less than 1/2 hour. Also learned that a clean unpainted clothes hanger wire placed inside the plastic tube can be bent to drain the fluid to where you want it to drain-this minimizes the worry about a hose moving where you don't want it to go. Worked for me. The members of this discussion board, and the archives they've accumulated are a real treasure. I learn something of value each time I search. Thanks again for helping me survive bleeding the master cylinder and lines. Jim
