If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I'm re-doing some of my wire connectors on my 71 small block. Should I use a conductive lube? If so, what kind and what is the primary purpose of using such a product?
There are various manufacturers of Dialectric Grease (I like Permatex the best) that I use on every electrical connection there is. First off, if you ever have to pull the connection apart again (ie. pulling plug wires off of plugs) it makes the job a lot easier-it keeps the boots from corroding and freezing onto the plugs. It keeps water/moisture out of the connection and keeps spark plug boots & other insulating materials pliable and less condusive to drying out. Get a big tube of it, and put a dab on the tip of your spark plugs and in the conductors in your distributor cap. Mandatory stuff for your toolbox.
I believe you are looking for conductive lube. Dielectric grease as mentioned by the previous poster iis the opposite; it provides insulating properties yet prevents items such as spark plug boots from siezing to the plugs.
As far as a conductive grease, I use a copper-colored product. It stains everything it touches but workes extremely well, especially on plug connections or other items that may someday need to be removed. Sorry but I don't recall the name as I long ago decanted it into a smaller container. But you'll know it when you find it by the copper color (it has bits of copper embedded in the grease).
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
