Those of you that judge or have had your car judged know the terminology used on the judging sheets. Not typical, service replacment, etc.
I have in front of me a weird 64-65 baseplate (also know to some as an adapter plate or just a plain old intake manifold).
It's the typical 3826810 casting number with GM under the number. The number is in the usual spot on the top side. Above this number there is a raised pad like an engine block casting date which has 2/27/65. Those of you that know FI's are aware of the fact that this is NOT TYPICAL.
Now a TYPICAL FI baseplate from '57 to 65 is dated underneath where the hot oil hits the numbers.
This baseplate is dated underneath also. Dated: 2 3. 64 EJ !!!
JD here has been playing with FI's since 1961 which is more years than I care to remember. Anyhow in all these long years this is the 3rd one of these critters I have seen.
Recap: It has two casting dates on it. Underneath is 2 3 64. On top it is dated 2/27/65.
Any ideas guru's??? Thanks very much, John D.
P.S. It is a loose part. Meaning it did not come with a customers FI unit so I have no clue of the serial number of the Corvette.
. Bob
