Tri-power carb wrench needed - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    I'm looking where I can purchase a special very thin wrench to hold the fuel inlet tube fittings .
    that large nut fitting that reduces down to except the gas line fittings at the carb body.
  • Joe D.
    • April 30, 2002
    • 382
    Re: Tri-power carb wrench needed
    I bough a set of craftsman ignition wrench many years ago. I am not sure if they still sell them or if they will help you. They are thin.
    • Wayne P.
      • August 31, 1975
      • 1025
      Take an old wrench and grind it down to size.
      • Ray G.
        • May 31, 1986
        • 1187
        Hello;
        Have a MAC Tools 1" wrench, for many years.
        Try your local Auto technician. He can probably direct you to a Tool Man.
        Hope that helps.
        Ray
        I hope you dance
          • May 31, 1974
          • 8365
          Originally posted by Ray Geiger (9992)
          Hello;
          Hope that helps.
          Ray
          try the snap-on truck for a 1" tappet open end wrench. its thin enough to grasp the fitting.mike
          • Craig O.
            • July 31, 1983
            • 207
            Thanks all
            • Ken A.
              • July 31, 1986
              • 929
              You do not need a wrench for the filter housing. It should have been tight BEFORE you installed the carbs,
              • Michael B.
                • June 18, 2007
                • 400
                You certainly need to backup that nut if you are going to get the fuel line back off or change the filter with the carb on the car.
                I have a fitting on one carb that I can actually get a wrench on. It's not correct for the Corvette. I was told it was from a Mopar Holley 2300 6-Pack setup. Don't know if that true, but I can say there is a better fitting in existance.
